Samsung Galaxy A10 Back Cover Replacement
Adriana Zwink
Adriana Zwink and one other contributor
Last updated on May 22, 2021
5 - 10 minutes
Moderate
Introduction
Go to step 1
Use this guide to remove or replace a damaged back cover on your Galaxy A10.
  1. Samsung Galaxy A10 Back Cover Replacement, Samsung Galaxy A10 SIM Tray Replacement: step 1, image 1 of 2 Samsung Galaxy A10 Back Cover Replacement, Samsung Galaxy A10 SIM Tray Replacement: step 1, image 2 of 2
    • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
    • Press firmly to eject the tray.
    Habe nur das Frontglas mit Werkzeug gekauft. Kann ich nur dieses von vorn ersetzen, ohne das Gerät komplett zerlegen zu müssen? Sprich defektes Glas erhitzen und nach vorn abheben etc
    Hans Weschta - Reply
    Hallo Hans, leider musst du dein A10 zerlegen um den Screen zu wechseln. Hier ist der Guide für deine Reparatur: Samsung Galaxy A10 Screen Replacement. Viel Erfolg beim Reparieren!
    Adriana Zwink -
  2. Samsung Galaxy A10 Back Cover Replacement: step 2, image 1 of 2 Samsung Galaxy A10 Back Cover Replacement: step 2, image 2 of 2
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  3. Samsung Galaxy A10 Back Cover Replacement, Back Cover: step 3, image 1 of 2 Samsung Galaxy A10 Back Cover Replacement, Back Cover: step 3, image 2 of 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
    High located in charging pot only?
    AK FRIENDS - Reply
  4. Samsung Galaxy A10 Back Cover Replacement: step 4, image 1 of 3 Samsung Galaxy A10 Back Cover Replacement: step 4, image 2 of 3 Samsung Galaxy A10 Back Cover Replacement: step 4, image 3 of 3
    • Slide the opening pick to the bottom left corner to release the clips.
  5. Samsung Galaxy A10 Back Cover Replacement: step 5, image 1 of 3 Samsung Galaxy A10 Back Cover Replacement: step 5, image 2 of 3 Samsung Galaxy A10 Back Cover Replacement: step 5, image 3 of 3
    • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
  6. Samsung Galaxy A10 Back Cover Replacement: step 6, image 1 of 3 Samsung Galaxy A10 Back Cover Replacement: step 6, image 2 of 3 Samsung Galaxy A10 Back Cover Replacement: step 6, image 3 of 3
    • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
  7. Samsung Galaxy A10 Back Cover Replacement: step 7, image 1 of 3 Samsung Galaxy A10 Back Cover Replacement: step 7, image 2 of 3 Samsung Galaxy A10 Back Cover Replacement: step 7, image 3 of 3
    • Slide the opening pick from the top left corner to the bottom right corner to release the remaining clips.
  8. Samsung Galaxy A10 Back Cover Replacement: step 8, image 1 of 2 Samsung Galaxy A10 Back Cover Replacement: step 8, image 2 of 2
    • Remove the back cover.
    What if screen separates from back cover and MB assy?
    h2opro - Reply
24 other people completed this guide.
Adriana Zwink
56,693 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,632 Guides authored
1 Guide Comment
why is this moderate
LambdaMisc - Reply
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 172
All Time: 17,927
