Samsung Galaxy A10 Charging Port Replacement
Video Overview
  1. Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: step 1, image 1 of 3 Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: step 1, image 2 of 3 Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: step 1, image 3 of 3
    • Remove the SIM Tray.
    • Use plastic tools to separate the back cover.
  2. Samsung Galaxy A10 Charging Port Replacement: step 2, image 1 of 3 Samsung Galaxy A10 Charging Port Replacement: step 2, image 2 of 3 Samsung Galaxy A10 Charging Port Replacement: step 2, image 3 of 3
    • Remove the silver Phillips screws to be able to disassemble the motherboard shields.
  3. Samsung Galaxy A10 Charging Port Replacement: step 3, image 1 of 3 Samsung Galaxy A10 Charging Port Replacement: step 3, image 2 of 3 Samsung Galaxy A10 Charging Port Replacement: step 3, image 3 of 3
    • Disconnect the battery.
    • Remove the screws and the charging board shield.
  4. Samsung Galaxy A10 Charging Port Replacement, Remove the charging board: step 4, image 1 of 2 Samsung Galaxy A10 Charging Port Replacement, Remove the charging board: step 4, image 2 of 2
    • Disconnect the Main flex cable and the coaxial antenna cables and remove the charging board.
  5. Samsung Galaxy A10 Charging Port Replacement: step 5, image 1 of 3 Samsung Galaxy A10 Charging Port Replacement: step 5, image 2 of 3 Samsung Galaxy A10 Charging Port Replacement: step 5, image 3 of 3
    • Cover the microphone hole to prevent microphone damage.
    • Use hot air to remove the Micro USB connector.
  6. Samsung Galaxy A10 Charging Port Replacement: step 6, image 1 of 3 Samsung Galaxy A10 Charging Port Replacement: step 6, image 2 of 3 Samsung Galaxy A10 Charging Port Replacement: step 6, image 3 of 3
    • Clean the tin and install the new charging connector.
  7. Samsung Galaxy A10 Charging Port Replacement: step 7, image 1 of 2 Samsung Galaxy A10 Charging Port Replacement: step 7, image 2 of 2
    • Clean the board and test the device.
11 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
One Comment
Waste of time unless you're obsessed with soldering. Just buy a complete board. Cheaper, easier and quicker.
[deleted] - Reply
Past 24 Hours: 11
Past 7 Days: 54
Past 30 Days: 246
All Time: 7,743
