Samsung Galaxy A20e Battery Replacement
  1. Samsung Galaxy A20e Battery Replacement, Remove the SIM tray: step 1, image 1 of 3 Samsung Galaxy A20e Battery Replacement, Remove the SIM tray: step 1, image 2 of 3 Samsung Galaxy A20e Battery Replacement, Remove the SIM tray: step 1, image 3 of 3
    • Before starting repairs, take your Galaxy A20e off the charger and power it down.
    • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located on the left side of the phone.
    • Press your SIM card eject tool firmly into the hole in order to eject the SIM card tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Samsung Galaxy A20e Battery Replacement, Unclip the plastic clips: step 2, image 1 of 2 Samsung Galaxy A20e Battery Replacement, Unclip the plastic clips: step 2, image 2 of 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick between the screen and the back cover on the left edge next to the hole for the SIM-eject tool.
  3. Samsung Galaxy A20e Battery Replacement: step 3, image 1 of 3 Samsung Galaxy A20e Battery Replacement: step 3, image 2 of 3 Samsung Galaxy A20e Battery Replacement: step 3, image 3 of 3
    • Slide the opening pick around the bottom left corner to unclip the plastic clips.
  4. Samsung Galaxy A20e Battery Replacement: step 4, image 1 of 2 Samsung Galaxy A20e Battery Replacement: step 4, image 2 of 2
    • Slide the opening pick along the bottom edge to unclip the plastic clips.
  5. Samsung Galaxy A20e Battery Replacement: step 5, image 1 of 2 Samsung Galaxy A20e Battery Replacement: step 5, image 2 of 2
    • Slide the opening pick along the right edge to the top right corner to unclip the plastic clips.
  6. Samsung Galaxy A20e Battery Replacement, Remove the back cover: step 6, image 1 of 2 Samsung Galaxy A20e Battery Replacement, Remove the back cover: step 6, image 2 of 2
    • Separate the phone assembly from the back cover.
  7. Samsung Galaxy A20e Battery Replacement, Disconnect the fingerprint sensor: step 7, image 1 of 2 Samsung Galaxy A20e Battery Replacement, Disconnect the fingerprint sensor: step 7, image 2 of 2
    • Use an opening pick to pry up and disconnect the fingerprint sensor.
  8. Samsung Galaxy A20e Battery Replacement, Loosen the fingerprint sensor: step 8, image 1 of 2 Samsung Galaxy A20e Battery Replacement, Loosen the fingerprint sensor: step 8, image 2 of 2
    • Push against the left edge of the fingerprint sensor with an opening pick to slide the sensor to the right and separate it from the motherboard cover.
  9. Samsung Galaxy A20e Battery Replacement, Remove the fingerprint sensor: step 9, image 1 of 1
    • Remove the fingerprint sensor.
  10. Samsung Galaxy A20e Battery Replacement, Unfasten the screws: step 10, image 1 of 1
    • Use a Phillips screwdriver to remove the six 3.5 mm-long screws securing the motherboard covers.
  11. Samsung Galaxy A20e Battery Replacement, Unclip the upper motherboard cover: step 11, image 1 of 2 Samsung Galaxy A20e Battery Replacement, Unclip the upper motherboard cover: step 11, image 2 of 2
    • Slide an opening pick under the upper motherboard cover.
    • Use the opening pick to unclip the plastic clips, which are holding the upper motherboard cover in its place.
  12. Samsung Galaxy A20e Battery Replacement, Remove the motherboard covers: step 12, image 1 of 2 Samsung Galaxy A20e Battery Replacement, Remove the motherboard covers: step 12, image 2 of 2
    • Remove the upper motherboard cover.
    • Remove the lower motherboard cover.
  13. Samsung Galaxy A20e Battery Replacement, Disconnect the battery: step 13, image 1 of 2 Samsung Galaxy A20e Battery Replacement, Disconnect the battery: step 13, image 2 of 2
    • Use an opening pick to disconnect the battery by prying the connector straight up from its socket.
  14. Samsung Galaxy A20e Battery Replacement, Disconnect the flex cables: step 14, image 1 of 3 Samsung Galaxy A20e Battery Replacement, Disconnect the flex cables: step 14, image 2 of 3 Samsung Galaxy A20e Battery Replacement, Disconnect the flex cables: step 14, image 3 of 3
    • Use the opening pick to disconnect the interconnect and display flex cables by prying the connectors straight up from their sockets.
  15. Samsung Galaxy A20e Battery Replacement, Free up the battery: step 15, image 1 of 2 Samsung Galaxy A20e Battery Replacement, Free up the battery: step 15, image 2 of 2
    • Bend the two flex cables toward the bottom of the phone and out of the way of the battery.
    • Take care not to crease the cables.
  16. Samsung Galaxy A20e Battery Replacement, Apply adhesive remover: step 16, image 1 of 1
    • Follow these preparation steps before using adhesive remover.
    • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol into the gap at the left edge of the battery.
    • Lift the bottom of your phone up to tilt it in the direction of the rear facing camera to let the adhesive remover spread out underneath the battery.
    • Let the adhesive remover penetrate the battery adhesive for at least 1 minute.
  17. Samsung Galaxy A20e Battery Replacement, Pry up the battery: step 17, image 1 of 3 Samsung Galaxy A20e Battery Replacement, Pry up the battery: step 17, image 2 of 3 Samsung Galaxy A20e Battery Replacement, Pry up the battery: step 17, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert a plastic card underneath the left edge of the battery.
    • Carefully slide it underneath the battery to loosen the adhesive.
    • Continue sliding the plastic card underneath to pry up the battery from its recess.
    • The battery should come off easily. In case the battery is still sticky, repeat the previous adhesive remover procedure.
  18. Samsung Galaxy A20e Battery Replacement, Remove the battery: step 18, image 1 of 1
    • Remove the battery.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
14 other people completed this guide.
Adriana Zwink
56,077 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,409 Guides authored
One Comment
Step by step instructions absolutely fantastic so easy to follow and took me hardly anytime to complete the task
David Oakley - Reply
Past 24 Hours: 13
Past 7 Days: 63
Past 30 Days: 255
All Time: 18,939
