Samsung Galaxy A3 2016 Back Cover Replacement
  1. Samsung Galaxy A3 2016 Back Cover Replacement, Back cover: step 1, image 1 of 3 Samsung Galaxy A3 2016 Back Cover Replacement, Back cover: step 1, image 2 of 3 Samsung Galaxy A3 2016 Back Cover Replacement, Back cover: step 1, image 3 of 3
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • Lift the bottom part of your back cover with a suction handle and insert an opening pick.
  2. Samsung Galaxy A3 2016 Back Cover Replacement: step 2, image 1 of 3 Samsung Galaxy A3 2016 Back Cover Replacement: step 2, image 2 of 3 Samsung Galaxy A3 2016 Back Cover Replacement: step 2, image 3 of 3
    • Slide the opening pick up to the rear camera to separate the back cover from the frame.
  3. Samsung Galaxy A3 2016 Back Cover Replacement: step 3, image 1 of 2 Samsung Galaxy A3 2016 Back Cover Replacement: step 3, image 2 of 2
    • Insert a second opening pick and move around the other corner at the bottom part of the back cover.
  4. Samsung Galaxy A3 2016 Back Cover Replacement: step 4, image 1 of 3 Samsung Galaxy A3 2016 Back Cover Replacement: step 4, image 2 of 3 Samsung Galaxy A3 2016 Back Cover Replacement: step 4, image 3 of 3
    • Move the second pick along the left side of the back cover to loosen the adhesive.
    • Move around the upper left corner and loosen the adhesive above the rear camera.
    • After loosening all the edges and sides of the back cover use an iOpener to loosen the adhesive underneath the center of it.
  5. Samsung Galaxy A3 2016 Back Cover Replacement: step 5, image 1 of 3 Samsung Galaxy A3 2016 Back Cover Replacement: step 5, image 2 of 3 Samsung Galaxy A3 2016 Back Cover Replacement: step 5, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Insert a plastic card at the bottom and slide it underneath the back cover.
    • Separate the glue until you reach the rear camera.
    • Now you can slowly lift up the back cover and finally remove it.
17 other people completed this guide.
Dominik Schnabelrauch
228,990 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,418 Guides authored
One Comment
where can I buy the back cover? tnx
rompecolleoni - Reply
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 33
All Time: 16,955
