Samsung Galaxy A50 Display Assembly with Frame Replacement
Video Overview
  1. Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: step 1, image 1 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: step 1, image 2 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: step 1, image 3 of 3
    • Display Touch Screen Digitizer Assembly with Frame for Samsung Galaxy A50
  2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: step 2, image 1 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: step 2, image 2 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: step 2, image 3 of 3
    • Heat up the back cover to loosen the adhesive.
    • To separate the back cover use a Suction Cup and plastic tools.
  3. Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: step 3, image 1 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: step 3, image 2 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: step 3, image 3 of 3
    • Remove the SIM tray.
    • Remove the Philips Screws.
    • Again use plastic tools to separate the middle frame.
  4. Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: step 4, image 1 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: step 4, image 2 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: step 4, image 3 of 3
    • First disconnect the Battery.
    • Test the new spare part before the installation.
  5. Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: step 5, image 1 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: step 5, image 2 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: step 5, image 3 of 3
    • Disconnect and remove the Main Flex Cable.
    • Remove the black Philips screw, it's shorter then the middle frame screws.
    • Disconnect the coaxial antenna cable.
    • Now you can remove the logic board.
  6. Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: step 6, image 1 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: step 6, image 2 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: step 6, image 3 of 3
    • First remove the Fingerprint sensor.
    • The screws for the Fingerprint are shorter.
    • It's better to use hot air before to disassemble the sub-board.
    • Reminder - only plastic tools :)
  7. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: step 7, image 1 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: step 7, image 2 of 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: step 7, image 3 of 3
    • Again, hot air, plastic tools and very slowly remove the battery.
  8. Samsung Galaxy A50 Display Assembly with Frame Replacement: step 8, image 1 of 1
    • All's Well That Ends Well
4 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
One Comment
The frame I bought doesn't have the place for earspeaker surrounded by little "walls", so it's very loose and doesn't have contact with the board. Anyone experienced this?
knezi - Reply
Past 24 Hours: 16
Past 7 Days: 87
Past 30 Days: 398
All Time: 14,472
