Samsung Galaxy A51 Midframe Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Samsung Galaxy A51 Midframe  Replacement, Samsung Galaxy A51 SIM Tray Removal: step 1, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement, Samsung Galaxy A51 SIM Tray Removal: step 1, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement, Samsung Galaxy A51 SIM Tray Removal: step 1, image 3 of 3
    • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Samsung Galaxy A51 Midframe  Replacement, Back Cover: step 2, image 1 of 1
    • Before beginning this procedure, completely power off your phone.
    • Prepare an iOpener and apply it to the back cover to soften the adhesive.
    • The adhesive of the Samsung Galaxy A51 is very strong. You can use a hair dryer or a heat gun if you aren't able to open the device with the iOpener.
    • Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy A51 Midframe  Replacement: step 3, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement: step 3, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement: step 3, image 3 of 3
    • Insert the tip of an opening pick between the frame and the back cover at the bottom of the phone near the USB-C port.
    • If you can't get between the back cover and midframe with your opening pick, you can use a suction handle or strong tape to pull up the back cover to create a gap.
    • Slide the opening pick to the bottom right corner and leave it there.
  4. Samsung Galaxy A51 Midframe  Replacement: step 4, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement: step 4, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement: step 4, image 3 of 3
    • Insert a second opening pick and slide it from the bottom right corner to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A51 Midframe  Replacement: step 5, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement: step 5, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement: step 5, image 3 of 3
    • Insert a third opening pick under the bottom left corner of the back cover.
    • If you have any trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick along the left edge of the phone.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A51 Midframe  Replacement: step 6, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement: step 6, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement: step 6, image 3 of 3
    • Insert a fourth opening pick under the top left corner of the back cover near the camera.
    • Slide the tip of the opening pick along the top edge of the phone to the right corner to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A51 Midframe  Replacement: step 7, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement: step 7, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement: step 7, image 3 of 3
    • With opening picks in all four corners, insert a fifth and final opening pick under the top right corner of the back cover.
    • Slide the tip of the opening pick along the right edge of the phone to the bottom right corner to cut the remaining adhesive.
  8. Samsung Galaxy A51 Midframe  Replacement: step 8, image 1 of 1
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Samsung Galaxy A51 Midframe  Replacement, Midframe: step 9, image 1 of 1
    • Remove the thirteen 3 mm Phillips #00 screws securing the midframe.
  10. Samsung Galaxy A51 Midframe  Replacement: step 10, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement: step 10, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement: step 10, image 3 of 3
    • The midframe is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the bottom of the phone near the charge port.
    • Slide the opening pick to the left bottom corner to release the plastic clips.
    • Slide the opening pick to the bottom right corner to release the rest of the bottom plastic clips.
  11. Samsung Galaxy A51 Midframe  Replacement: step 11, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement: step 11, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement: step 11, image 3 of 3
    • Continue sliding the opening pick on the right side of your phone until all plastic clips on the right side are released.
  12. Samsung Galaxy A51 Midframe  Replacement: step 12, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement: step 12, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement: step 12, image 3 of 3
    • Slide the opening pick along the top edge to release the top plastic clips.
  13. Samsung Galaxy A51 Midframe  Replacement: step 13, image 1 of 3 Samsung Galaxy A51 Midframe  Replacement: step 13, image 2 of 3 Samsung Galaxy A51 Midframe  Replacement: step 13, image 3 of 3
    • Slide the opening pick from the top left corner to the bottom left corner to release the left side's plastic clips.
  14. Samsung Galaxy A51 Midframe  Replacement: step 14, image 1 of 1
    • Remove the midframe.
Adriana Zwink
62,890 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 130
