Samsung Galaxy A7 (2018) Display Assembly Replacement
Video Overview
  1. Samsung Galaxy A7 (2018) Display Assembly Replacement, Display Assembly: step 1, image 1 of 2 Samsung Galaxy A7 (2018) Display Assembly Replacement, Display Assembly: step 1, image 2 of 2
    • It's better to use Display Assembly (Screen With Frame) to fix your broken device.
  2. Samsung Galaxy A7 (2018) Display Assembly Replacement, Battery Cover Removal: step 2, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Battery Cover Removal: step 2, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Battery Cover Removal: step 2, image 3 of 3
    • Use hot air to warm the device and soften the adhesive type.
    • Gently separate the back cover.
    • Use Suction Cup and a plastic opening tool (Paying cart).
  3. Samsung Galaxy A7 (2018) Display Assembly Replacement, Middle Frame Removal: step 3, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Middle Frame Removal: step 3, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Middle Frame Removal: step 3, image 3 of 3
    • You need a screwdriver Phillips to remove all 9 screws.
    • Again - using only Plastic tools remove the middle frame.
  4. Samsung Galaxy A7 (2018) Display Assembly Replacement, Test New Spare Part: step 4, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Test New Spare Part: step 4, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Test New Spare Part: step 4, image 3 of 3
    • Once you have access to the battery, disconnect it.
    • Test the new screen before installing it.
  5. Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub board Cover Removal: step 5, image 1 of 2 Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub board Cover Removal: step 5, image 2 of 2
    • Use Phillips Screwdriver and plastic tool and remove the Sub board cover.
  6. Samsung Galaxy A7 (2018) Display Assembly Replacement, Logic Board Removal: step 6, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Logic Board Removal: step 6, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Logic Board Removal: step 6, image 3 of 3
    • Remove the black Philips screw and gently take out the Mother board.
  7. Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub Board Removal: step 7, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub Board Removal: step 7, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub Board Removal: step 7, image 3 of 3
    • Remove the Antenna Sub-PBA board.
    • It's easier to take out the sub board if you warm it a little.
  8. Samsung Galaxy A7 (2018) Display Assembly Replacement, Receiver, Vibrator, Loudspeaker, Battery Transfer: step 8, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Receiver, Vibrator, Loudspeaker, Battery Transfer: step 8, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Receiver, Vibrator, Loudspeaker, Battery Transfer: step 8, image 3 of 3
    • Transfer to the New Screen frame:
    • Vibrator motor
    • Loudspeacker
    • Receiver
    • Use hot air and plastic tools to remove the battery.
  9. Samsung Galaxy A7 (2018) Display Assembly Replacement, That's all friends: step 9, image 1 of 1
    • That's all friends!
19 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
2 Comments
Hey!!!!!!. I’ve just recently fixed my A7 (2018) screen, and with this screen, you’ll have to remove the old one, and replace it. The adhesive what is on your old screen is very strong, So i advise to use isopropyl alcohol, and/or heat, also with suction, so that you can pry up the screen. Also, Do NOT bent the Flex Cable because it is very delicate, and it will tear easy. All in all, the repair was fun, for a repairman myself, and allowed me to use my talent!!. 10/10 Recommend
Marlion Russell - Reply
I want buy the screen for samsung a7 ?
Zouhair Guermah - Reply
Past 24 Hours: 14
Past 7 Days: 71
Past 30 Days: 297
All Time: 17,679
