Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement
Video Overview
  1. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement, Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera: step 1, image 1 of 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement, Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera: step 1, image 2 of 2
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory card.
  2. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 2, image 1 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 2, image 2 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 2, image 3 of 3
    • Remove the 7 Phillips screws.
    • Use a plastic tool to remove the back cover.
    • vibrating motor
  3. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 3, image 1 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 3, image 2 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 3, image 3 of 3
    • Disconnect the earpiece & light sensor flex cable.
    • Take off the Volume Up/Down buttons flex cable.
    • Do the same with the Power button flex cable.
    • Be careful don't brake the flex cables.
  4. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 4, image 1 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 4, image 2 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 4, image 3 of 3
    • Lift the microphone.
    • Lift the board from the right side and disconnect the LCD display flex cable.
    • Remove the board from the middle frame.
  5. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 5, image 1 of 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 5, image 2 of 2
    • This is the main camera.
  6. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 6, image 1 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 6, image 2 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 6, image 3 of 3
    • This is the loudspeaker & audio jack connector module.
  7. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 7, image 1 of 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 7, image 2 of 2
    • Loudspeaker and light sensor module,
  8. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 8, image 1 of 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 8, image 2 of 2
    • Disconnect the touch screen flex cable.
  9. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 9, image 1 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 9, image 2 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 9, image 3 of 3
    • Use a hair dryer and warm the touch screen glass to make adhesive soften.
    • Use a plastic tool for separating the glass from the middle frame.
  10. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 10, image 1 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 10, image 2 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 10, image 3 of 3
    • Again by using a plastic tool, separate the LCD display from the middle frame.
  11. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 11, image 1 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 11, image 2 of 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 11, image 3 of 3
    • Clean the middle frame and install the LCD display.
  12. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 12, image 1 of 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 12, image 2 of 2
    • Install the touch screen and start with reassembling.
  13. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: step 13, image 1 of 1
    • That is all.
    • Did you do it successfully?
23 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
One Comment
Amar touch ta lagbe
nj nazmul - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 31
All Time: 9,380
