Samsung Galaxy Alpha Back Cover Replacement
  1. Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: step 1, image 1 of 3 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: step 1, image 2 of 3 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: step 1, image 3 of 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
To replace the cover, realign the cover with the device and gently press down until you hear the connections click.
13 other people completed this guide.
Sarah
940 Reputation
2 Guides authored
Cal Poly, Team 20-17, Maness Winter 2015 Member of Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 3,761
