Samsung Galaxy Alpha microSIM Card Replacement
  1. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: step 1, image 1 of 3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: step 1, image 2 of 3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: step 1, image 3 of 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha microSIM Card Replacement, Battery: step 2, image 1 of 2 Samsung Galaxy Alpha microSIM Card Replacement, Battery: step 2, image 2 of 2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
  3. Samsung Galaxy Alpha microSIM Card Replacement, microSIM Card: step 3, image 1 of 1
    • Remove your Micro SIM card from the slot shown.
11 other people completed this guide.
Tyler
769 Reputation
1 Guide authored
Cal Poly, Team 20-17, Maness Winter 2015 Member of Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 2,614
