Samsung Galaxy Amp 2 Screen Replacement
  1. Samsung Galaxy Amp 2 Screen Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Amp 2 Screen Replacement, Battery: step 1, image 2 of 2
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Screen Replacement: step 2, image 1 of 3 Samsung Galaxy Amp 2 Screen Replacement: step 2, image 2 of 3 Samsung Galaxy Amp 2 Screen Replacement: step 2, image 3 of 3
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Screen Replacement, Screen: step 3, image 1 of 3 Samsung Galaxy Amp 2 Screen Replacement, Screen: step 3, image 2 of 3 Samsung Galaxy Amp 2 Screen Replacement, Screen: step 3, image 3 of 3
    Tool used on this step:
    $3.99
    Buy
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Screen Replacement: step 4, image 1 of 1
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Screen Replacement: step 5, image 1 of 3 Samsung Galaxy Amp 2 Screen Replacement: step 5, image 2 of 3 Samsung Galaxy Amp 2 Screen Replacement: step 5, image 3 of 3
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
6 other people completed this guide.
Cory Nickolatos
415 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
4 Members
5 Guides authored
2 Comments
I broke the screen on the same day I bought the phone. I have ordered a new one from ebay. I am going to try to install the screen with LCD digitizer.
Amresh Kadian - Reply
I had an amp 2 phone i accidently smashed it with my ps3 controller when I was playing games I smashed it on purpose so is this the way to fix the phone
darkwatch205 - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,209
