Samsung Galaxy Amp 2 Speaker Replacement
  1. Samsung Galaxy Amp 2 Speaker Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Amp 2 Speaker Replacement, Battery: step 1, image 2 of 2
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Speaker Replacement: step 2, image 1 of 3 Samsung Galaxy Amp 2 Speaker Replacement: step 2, image 2 of 3 Samsung Galaxy Amp 2 Speaker Replacement: step 2, image 3 of 3
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Speaker Replacement, Screen: step 3, image 1 of 3 Samsung Galaxy Amp 2 Speaker Replacement, Screen: step 3, image 2 of 3 Samsung Galaxy Amp 2 Speaker Replacement, Screen: step 3, image 3 of 3
    Tool used on this step:
    $3.99
    Buy
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Speaker Replacement: step 4, image 1 of 1
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Speaker Replacement: step 5, image 1 of 3 Samsung Galaxy Amp 2 Speaker Replacement: step 5, image 2 of 3 Samsung Galaxy Amp 2 Speaker Replacement: step 5, image 3 of 3
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Speaker Replacement, Motherboard: step 6, image 1 of 3 Samsung Galaxy Amp 2 Speaker Replacement, Motherboard: step 6, image 2 of 3 Samsung Galaxy Amp 2 Speaker Replacement, Motherboard: step 6, image 3 of 3
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
  7. Samsung Galaxy Amp 2 Speaker Replacement, Speaker: step 7, image 1 of 2 Samsung Galaxy Amp 2 Speaker Replacement, Speaker: step 7, image 2 of 2
    • Gently pull the black piece that is connected to the top of the motherboard. This is the speaker.
Cory Nickolatos
415 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 403
