Samsung Galaxy Attain 4G Battery Replacement
  1. Samsung Galaxy Attain 4G Battery Replacement, Placement: step 1, image 1 of 1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Battery Replacement, Battery Door Removal: step 2, image 1 of 2 Samsung Galaxy Attain 4G Battery Replacement, Battery Door Removal: step 2, image 2 of 2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: step 3, image 1 of 3 Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: step 3, image 2 of 3 Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: step 3, image 3 of 3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Battery Replacement, Heads Up!: step 4, image 1 of 1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
Josh Forester
2,505 Reputation
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 405
