Samsung Galaxy Book Pro 15" Heat Sink Replacement
  1. Samsung Galaxy Book Pro 15" Heat Sink Replacement, Remove the rubber feet: step 1, image 1 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Remove the rubber feet: step 1, image 2 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Remove the rubber feet: step 1, image 3 of 3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
  2. Samsung Galaxy Book Pro 15" Heat Sink Replacement, Unfasten the rear case: step 2, image 1 of 2 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Unfasten the rear case: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
  3. Samsung Galaxy Book Pro 15" Heat Sink Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Insert an opening pick: step 3, image 3 of 3
    • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy Book Pro 15" Heat Sink Replacement, Release the clips: step 4, image 1 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Release the clips: step 4, image 2 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Release the clips: step 4, image 3 of 3
    • Slide the pick along the bottom edge of the rear case to release its plastic clips.
    • Repeat this process for the left and right edges, but stop before reaching the top edge.
  5. Samsung Galaxy Book Pro 15" Heat Sink Replacement, Remove the rear case: step 5, image 1 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Remove the rear case: step 5, image 2 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Remove the rear case: step 5, image 3 of 3
    • The top edge of the rear case is lightly adhered to the frame.
    • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
    • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
    • Remove the rear case.
    • During reassembly, perform the following:
    • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
    • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
    • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
  6. Samsung Galaxy Book Pro 15" Heat Sink Replacement, Disconnect the battery: step 6, image 1 of 2 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Disconnect the battery: step 6, image 2 of 2
    • Insert a spudger between the frame and the bottom of the battery cable connector.
    • Pry up and disconnect the battery cable connector.
  7. Samsung Galaxy Book Pro 15" Heat Sink Replacement, Unfasten the heat sink: step 7, image 1 of 2 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Unfasten the heat sink: step 7, image 2 of 2
    • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the heat sink.
  8. Samsung Galaxy Book Pro 15" Heat Sink Replacement, Remove the heat sink: step 8, image 1 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Remove the heat sink: step 8, image 2 of 3 Samsung Galaxy Book Pro 15" Heat Sink Replacement, Remove the heat sink: step 8, image 3 of 3
    • Lift the left edge of the heat sink upward to separate the heat sink from the motherboard.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the motherboard with thermal paste.
    • Remove the heat sink.
    • Follow this guide for how to clean and reapply thermal paste.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Alex Diaz-Kokaisl
129,318 Reputation
600 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,077 Guides authored
One Comment
Is there a certain screwdriver size that fits the heat sinc screwsm
Charlie - Reply
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 11
All Time: 219
