Samsung Galaxy Book Pro 15" Primary SSD Replacement
  1. Samsung Galaxy Book Pro 15" Primary SSD Replacement, Remove the rubber feet: step 1, image 1 of 3 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Remove the rubber feet: step 1, image 2 of 3 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Remove the rubber feet: step 1, image 3 of 3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
  2. Samsung Galaxy Book Pro 15" Primary SSD Replacement, Unfasten the rear case: step 2, image 1 of 2 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Unfasten the rear case: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
  3. Samsung Galaxy Book Pro 15" Primary SSD Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Insert an opening pick: step 3, image 3 of 3
    • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy Book Pro 15" Primary SSD Replacement, Release the clips: step 4, image 1 of 3 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Release the clips: step 4, image 2 of 3 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Release the clips: step 4, image 3 of 3
    • Slide the pick along the bottom edge of the rear case to release its plastic clips.
    • Repeat this process for the left and right edges, but stop before reaching the top edge.
  5. Samsung Galaxy Book Pro 15" Primary SSD Replacement, Remove the rear case: step 5, image 1 of 3 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Remove the rear case: step 5, image 2 of 3 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Remove the rear case: step 5, image 3 of 3
    • The top edge of the rear case is lightly adhered to the frame.
    • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
    • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
    • Remove the rear case.
    • During reassembly, perform the following:
    • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
    • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
    • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
  6. Samsung Galaxy Book Pro 15" Primary SSD Replacement, Disconnect the battery: step 6, image 1 of 2 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Disconnect the battery: step 6, image 2 of 2
    • Insert a spudger between the frame and the bottom of the battery cable connector.
    • Pry up and disconnect the battery cable connector.
  7. Samsung Galaxy Book Pro 15" Primary SSD Replacement, Unfasten the SSD: step 7, image 1 of 2 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Unfasten the SSD: step 7, image 2 of 2
    • Use a Phillips screwdriver to remove the 3.5 mm-long screw securing the SSD.
  8. Samsung Galaxy Book Pro 15" Primary SSD Replacement, Remove the SSD: step 8, image 1 of 2 Samsung Galaxy Book Pro 15" Primary SSD Replacement, Remove the SSD: step 8, image 2 of 2
    • Lift the free end of the SSD up slightly and pull the SSD straight out of its socket on the motherboard.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Alex Diaz-Kokaisl
127,654 Reputation
592 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 684
