Introduction
In this replacement guide, you will be tasked with removing the screen. If your screen is cracked, make sure to handle the part with care, as some pieces of glass could fall off. To prevent this, put clear packing tape over the screen to keep it intact. Always remember to remove the battery before you take the camera apart.
Face the camera towards you, then rotate it such that the battery door is facing up and to the right.
While holding the camera, take note of each screw holding the screen to the main chassis of the camera.
Hold the camera upright and lens facing towards you. There area total of six 4mm PH00 screws to undo - two on the left, one screw on the right, and three along the bottom. Two of them are hidden behind the battery compartment door.
With the screws removed, use the plastic opening tool to gently pry the screen away from the main camera chassis. The ideal spot to start is at the corner with the headphone jack, as indicated in the picture.
Once this side is free, gently work your way along the edge, all the way around the camera body.
9 other people completed this guide.
7 Guide Comments
I need to replace the screen and keep the. White around it. How do I do that
You have to use a hair dryer on high on the screen until you can get it loose from the white frame. Carefully pry under the screen with a small screwdriver or a plastic tool to get it loose and then run the plastic tool around the edges until it is loose. It is held in by some type of double sided tape.
clhowey -
after part sales comes only with lcd screen, my question is how do you remove the broken lcd from the housing?
This is a incomplete guide.
