Samsung Galaxy Camera Battery Replacement
  1. Samsung Galaxy Camera Battery Replacement, Battery: step 1, image 1 of 1
    • Lift aside the casing for the battery using a plastic opening tool. This compartment is on the bottom of the camera, not under the lens.
    • The casing is highlighted in the red markup circle.
  2. Samsung Galaxy Camera Battery Replacement: step 2, image 1 of 1
    • The slot for the battery should look like this. This is the case for the battery.
  3. Samsung Galaxy Camera Battery Replacement: step 3, image 1 of 2 Samsung Galaxy Camera Battery Replacement: step 3, image 2 of 2
    • Using plastic opening tool, slide battery capture latch back and allow battery to fall out.
    • Insert your replacement battery.
  4. Samsung Galaxy Camera Battery Replacement: step 4, image 1 of 2 Samsung Galaxy Camera Battery Replacement: step 4, image 2 of 2
    • After the battery has been replaced, close the battery casing.
    • Now replace the casing from step one. Success, the battery has been replaced!
These steps follow completely: there is no need to reverse the order of steps to reassemble.
8 other people completed this guide.
Derek Brown
168 Reputation
1 Guide authored
IUPUI, Team 2-3, Wilson Fall 2015 Member of IUPUI, Team 2-3, Wilson Fall 2015
IUPUI-WILSON-F15S2G3
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 51
All Time: 3,690
