Samsung Galaxy Centura Camera Replacement
  1. Samsung Galaxy Centura Camera Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Centura Camera Replacement, Battery: step 1, image 2 of 2
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Camera Replacement: step 2, image 1 of 3 Samsung Galaxy Centura Camera Replacement: step 2, image 2 of 3 Samsung Galaxy Centura Camera Replacement: step 2, image 3 of 3
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Camera Replacement, Camera: step 3, image 1 of 1
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Camera Replacement: step 4, image 1 of 3 Samsung Galaxy Centura Camera Replacement: step 4, image 2 of 3 Samsung Galaxy Centura Camera Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Locate the three metal clips holding the camera in place, and pull these clips away from the camera using the tweezers.
    • Use the tweezers to lift the camera out of the plastic housing. It should come free without resistance.
Austin Erickson
354 Reputation
3 Guides authored
USF Tampa, Team S2-G5, Nance Spring 2017 Member of USF Tampa, Team S2-G5, Nance Spring 2017
USFT-NANCE-S17S2G5
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 268
