Samsung Galaxy Core Display Replacement
  1. Samsung Galaxy Core Display Replacement, Display: step 1, image 1 of 2 Samsung Galaxy Core Display Replacement, Display: step 1, image 2 of 2
    • Turn the phone off
    • Remove the back cover
    • Extract battery
  2. Samsung Galaxy Core Display Replacement: step 2, image 1 of 1
    • Remove the 9 screws
  3. Samsung Galaxy Core Display Replacement: step 3, image 1 of 1
    • Remove the central frame to access the motherboard, help yourself with a thin tool
    • Remove the black screw that secures the lower motherboard
  4. Samsung Galaxy Core Display Replacement: step 4, image 1 of 3 Samsung Galaxy Core Display Replacement: step 4, image 2 of 3 Samsung Galaxy Core Display Replacement: step 4, image 3 of 3
    • Unclip the 3 connectors
    • Disconnect the connection cable of the 2 motherboards
    • With a flat instrument, help yourself to unhook the motherboard
  5. Samsung Galaxy Core Display Replacement: step 5, image 1 of 3 Samsung Galaxy Core Display Replacement: step 5, image 2 of 3 Samsung Galaxy Core Display Replacement: step 5, image 3 of 3
    • Remove top motherboard
    • Remove Speaker
    • Remove the lower motherboard with the help of a hot air hairdryer to help it detach from the adhesive
  6. Samsung Galaxy Core Display Replacement: step 6, image 1 of 2 Samsung Galaxy Core Display Replacement: step 6, image 2 of 2
    • If the touch screen glass is broken, use tape to avoid injury
    • Disconnect the TouchScreen connector
  7. Samsung Galaxy Core Display Replacement: step 7, image 1 of 1
    • Remove the touchscreen with thin tools between the glass and the central cover with the aid of a hair dryer or heat so that you can loosen the adhesive grip
    • Be careful in the part of the buttons and the flat cable of the touchscreen if you need to use it again and do not replace it with a new one
  8. Samsung Galaxy Core Display Replacement: step 8, image 1 of 3 Samsung Galaxy Core Display Replacement: step 8, image 2 of 3 Samsung Galaxy Core Display Replacement: step 8, image 3 of 3
    • Remove the display with thin tools, using heat to detach the fixing adhesive
To Reassemble your device, Follow these instruction reverse order.
3 other people completed this guide.
Special thanks to these translators:
it en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,366 Reputation
39 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 16
All Time: 1,312
