Samsung Galaxy Core Prime Home Button Replacement
  1. Samsung Galaxy Core Prime Home Button  Replacement, Battery: step 1, image 1 of 1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Home Button  Replacement: step 2, image 1 of 1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Home Button  Replacement: step 3, image 1 of 1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Home Button  Replacement: step 4, image 1 of 2 Samsung Galaxy Core Prime Home Button  Replacement: step 4, image 2 of 2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Home Button  Replacement: step 5, image 1 of 1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Home Button  Replacement, Home Button: step 6, image 1 of 1
    • Use your thumb to remove the sim card.
  7. Samsung Galaxy Core Prime Home Button  Replacement: step 7, image 1 of 2 Samsung Galaxy Core Prime Home Button  Replacement: step 7, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws that secure the midframe.
  8. Samsung Galaxy Core Prime Home Button  Replacement: step 8, image 1 of 1
    • Heat the frame with a hair dryer or heat gun. Do this until the adhesive is loosened.
    • Take care when using these heating tools.
  9. Samsung Galaxy Core Prime Home Button  Replacement: step 9, image 1 of 1
    Tool used on this step:
    iFixit Opening Tool
    $1.99
    Buy
  10. Samsung Galaxy Core Prime Home Button  Replacement: step 10, image 1 of 2 Samsung Galaxy Core Prime Home Button  Replacement: step 10, image 2 of 2
    Buy
    • Disconnect the LCD screen/touch screen ribbon from the motherboard using tweezers.
  11. Samsung Galaxy Core Prime Home Button  Replacement: step 11, image 1 of 1
    iFixit Opening Tool
    $1.99
    Buy
  12. Samsung Galaxy Core Prime Home Button  Replacement: step 12, image 1 of 1
    • Heat the sides of the screen with a heat gun or hair dryer.
  13. Samsung Galaxy Core Prime Home Button  Replacement: step 13, image 1 of 1
    iFixit Opening Tool
    $1.99
    Buy
    • Use the iFixit Opening Tool to remove the plastic panel that separates the motherboard and the screen.
  14. Samsung Galaxy Core Prime Home Button  Replacement: step 14, image 1 of 1
    • Use tweezers to remove the home button.
Kate Vogel
187 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,696
