Samsung Galaxy Core Prime Screen Replacement
  1. Samsung Galaxy Core Prime Screen Replacement, Battery: step 1, image 1 of 1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Screen Replacement: step 2, image 1 of 1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Screen Replacement: step 3, image 1 of 1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Screen Replacement: step 4, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 4, image 2 of 2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Screen Replacement: step 5, image 1 of 1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Screen Replacement, Screen: step 6, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement, Screen: step 6, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
  7. Samsung Galaxy Core Prime Screen Replacement: step 7, image 1 of 1
    • Use a heat gun or hair dryer to loosen the adhesive between the midframe and the rest of the device.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Screen Replacement: step 8, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 8, image 2 of 2
    Tool used on this step:
    iFixit Opening Tool
    $1.99
    Buy
  9. Samsung Galaxy Core Prime Screen Replacement: step 9, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 9, image 2 of 2
    Buy
    • Use tweezers to disconnect the power ribbon from the motherboard.
  10. Samsung Galaxy Core Prime Screen Replacement: step 10, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 10, image 2 of 2
    • Use tweezers or your hand to remove the audiojack.
  11. Samsung Galaxy Core Prime Screen Replacement: step 11, image 1 of 1
    iFixit Opening Tool
    $1.99
    Buy
  12. Samsung Galaxy Core Prime Screen Replacement: step 12, image 1 of 1
    iFixit Opening Tool
    $1.99
    Buy
    • Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
  13. Samsung Galaxy Core Prime Screen Replacement: step 13, image 1 of 3 Samsung Galaxy Core Prime Screen Replacement: step 13, image 2 of 3 Samsung Galaxy Core Prime Screen Replacement: step 13, image 3 of 3
    iFixit Opening Tool
    $1.99
    Buy
  14. Samsung Galaxy Core Prime Screen Replacement: step 14, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 14, image 2 of 2
    • Use tweezers to disconnect the digitizer.
7 other people completed this guide.
Cody Coombs
257 Reputation
1 Guide authored
1 Guide Comment
What if the phone does not come back on after assembly
nfl.ny.la.313 - Reply
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 21
All Time: 2,998
