Samsung Galaxy Express 3 Home Button Replacement
  1. Samsung Galaxy Express 3 Home Button Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement, Battery: step 1, image 2 of 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Home Button Replacement: step 2, image 1 of 3 Samsung Galaxy Express 3 Home Button Replacement: step 2, image 2 of 3 Samsung Galaxy Express 3 Home Button Replacement: step 2, image 3 of 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Home Button Replacement, Screen: step 3, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement, Screen: step 3, image 2 of 2
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
  4. Samsung Galaxy Express 3 Home Button Replacement: step 4, image 1 of 1
    • Detach the screen connector.
  5. Samsung Galaxy Express 3 Home Button Replacement: step 5, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement: step 5, image 2 of 2
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
  6. Samsung Galaxy Express 3 Home Button Replacement: step 6, image 1 of 3 Samsung Galaxy Express 3 Home Button Replacement: step 6, image 2 of 3 Samsung Galaxy Express 3 Home Button Replacement: step 6, image 3 of 3
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
  7. Samsung Galaxy Express 3 Home Button Replacement, Back and Recent Apps Touch Sensor Button(s): step 7, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement, Back and Recent Apps Touch Sensor Button(s): step 7, image 2 of 2
    • Use a plastic tool to remove back and/or recent tabs circuit buttons.
    • Use a plastic tool as a metal tool can be dangerous to the phone or you.
  8. Samsung Galaxy Express 3 Home Button Replacement, Home Button: step 8, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement, Home Button: step 8, image 2 of 2
    • Use a #0 Phillips bit screwdriver to remove the four screws from the black, plastic piece surrounding the home button.
    • All four screws are the same size.
  9. Samsung Galaxy Express 3 Home Button Replacement: step 9, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement: step 9, image 2 of 2
    • Using a sharp plastic tool such as a guitar pick or prying tool to pop up and remove the black, plastic piece.
    • Do not use a metal tool as it can be dangerous to you or the motherboard.
  10. Samsung Galaxy Express 3 Home Button Replacement: step 10, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement: step 10, image 2 of 2
    • The white button will be connected to the black piece.
    • Slightly bend the black piece and gently push the white button until it pops out of the black, plastic piece.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 419
