Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
Remove the five 4 mm screws with a Phillips#00 screwdriver.
Make sure you remove the sticker hiding the screw on the left bottom corner.
Using the plastic opening tool pry into the bezel to remove the mid-frame
Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
6 other people completed this guide.
