Samsung Galaxy Gear Battery Replacement
  1. Samsung Galaxy Gear Battery Replacement, Display Housing: step 1, image 1 of 1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Battery Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Battery Replacement: step 3, image 1 of 2 Samsung Galaxy Gear Battery Replacement: step 3, image 2 of 2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Battery Replacement, Battery: step 4, image 1 of 2 Samsung Galaxy Gear Battery Replacement, Battery: step 4, image 2 of 2
    • After separating the LCD/motherboard from the actual watch itself, the watch should be in two separate pieces.
    • You will only need the watch/strap component so you can set aside the LCD/motherboard component.
  5. Samsung Galaxy Gear Battery Replacement: step 5, image 1 of 3 Samsung Galaxy Gear Battery Replacement: step 5, image 2 of 3 Samsung Galaxy Gear Battery Replacement: step 5, image 3 of 3
    • Look for the metal bracket that covers and secures the battery in place.
    • Loosen the bracket by prying underneath the metal plating with the plastic opening tool. Remove the bracket and set it to the side.
    • The battery should now be exposed.
  6. Samsung Galaxy Gear Battery Replacement: step 6, image 1 of 3 Samsung Galaxy Gear Battery Replacement: step 6, image 2 of 3 Samsung Galaxy Gear Battery Replacement: step 6, image 3 of 3
    • Notice the leads attached to the base of the watch. You will need to remove this before you pull the battery out.
    • Using the plastic opening tool, pry underneath the leads and disconnect it from the back of the watch.
    • Slowly tug on the "PULL" tag and remove the battery from the watch.
11 other people completed this guide.
Edward Yi
424 Reputation
1 Guide authored
Cal Poly, Team 1-9, Maness Spring 2016 Member of Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 Members
7 Guides authored
4 Comments
WHERE DO I GET A NEW bATTERY & THE TOOLS; IS A COMPLETE KIT AVAILABLE?
rbilello - Reply
where do I get the battery & tools
steve ellis - Reply
“Parts
No parts required.”
I think a battery is required!
cyberjoe3d - Reply
Thank you very much
Adam P NYC
bori0916adam - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 13,590
