Samsung Galaxy Gear Display Housing Replacement
  1. Samsung Galaxy Gear Display Housing Replacement, Display Housing: step 1, image 1 of 1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Display Housing Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Display Housing Replacement: step 3, image 1 of 2 Samsung Galaxy Gear Display Housing Replacement: step 3, image 2 of 2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
Dalt Lasell
543 Reputation
2 Guides authored
Cal Poly, Team 1-9, Maness Spring 2016 Member of Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,333
