Samsung Galaxy Grand Midframe Replacement
  1. Samsung Galaxy Grand Midframe Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Grand Midframe Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Grand Midframe Replacement, Battery: step 1, image 3 of 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Midframe Replacement, Remove the battery.: step 2, image 1 of 3 Samsung Galaxy Grand Midframe Replacement, Remove the battery.: step 2, image 2 of 3 Samsung Galaxy Grand Midframe Replacement, Remove the battery.: step 2, image 3 of 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Midframe Replacement, Midframe: step 3, image 1 of 3 Samsung Galaxy Grand Midframe Replacement, Midframe: step 3, image 2 of 3 Samsung Galaxy Grand Midframe Replacement, Midframe: step 3, image 3 of 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Midframe Replacement: step 4, image 1 of 2 Samsung Galaxy Grand Midframe Replacement: step 4, image 2 of 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Midframe Replacement: step 5, image 1 of 2 Samsung Galaxy Grand Midframe Replacement: step 5, image 2 of 2
    • Make sure that you detach the mid-frame from the inside too.
42 other people completed this guide.
Kyle Ruff
6,749 Reputation
5 Guides authored
USF Tampa, Team 17-3, Blackwell Winter 2016 Member of USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Members
12 Guides authored
3 Comments
anyone can tell me how to swap vibrator motor?
Athaariq Ardiansyah Ramadhani - Reply
I need some glue to replace the midframe after having changed it?
Andrea Rossetti - Reply
not necessary
yasir -
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 12,486
