Samsung Galaxy Grand Prime Micro USB Port Replacement
  1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: step 1, image 3 of 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: step 2, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: step 2, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: step 2, image 3 of 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: step 3, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: step 3, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: step 3, image 3 of 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 4, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 4, image 2 of 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 5, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 5, image 2 of 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: step 6, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: step 6, image 2 of 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: step 7, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: step 7, image 2 of 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 8, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: step 9, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: step 9, image 2 of 2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 10, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 10, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 10, image 3 of 3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 11, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 11, image 2 of 2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
  12. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: step 12, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: step 12, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: step 12, image 3 of 3
    • Using a soldering iron to solder off the charging port.
    • Be careful soldering iron gets extremely hot.
33 other people completed this guide.
Kyle Ruff
6,749 Reputation
5 Guides authored
USF Tampa, Team 17-3, Blackwell Winter 2016 Member of USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 54
All Time: 34,863
