Samsung Galaxy J1 Front-Facing Camera Replacement
  1. Samsung Galaxy J1 Front-Facing Camera Replacement, Midframe: step 1, image 1 of 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Front-Facing Camera Replacement: step 2, image 1 of 2 Samsung Galaxy J1 Front-Facing Camera Replacement: step 2, image 2 of 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Front-Facing Camera Replacement: step 3, image 1 of 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Front-Facing Camera Replacement: step 4, image 1 of 3 Samsung Galaxy J1 Front-Facing Camera Replacement: step 4, image 2 of 3 Samsung Galaxy J1 Front-Facing Camera Replacement: step 4, image 3 of 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Front-Facing Camera Replacement, Front-Facing Camera: step 5, image 1 of 2 Samsung Galaxy J1 Front-Facing Camera Replacement, Front-Facing Camera: step 5, image 2 of 2
    • Use the flat end a spudger to disconnect the front-facing camera cable connecter.
  6. Samsung Galaxy J1 Front-Facing Camera Replacement: step 6, image 1 of 2 Samsung Galaxy J1 Front-Facing Camera Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, or your fingers, remove the front-facing camera.
12 other people completed this guide.
Sean Kramer
1,506 Reputation
6 Guides authored
USF Tampa, Team S5-G4, Eyestone Spring 2018 Member of USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 55
All Time: 3,126
