Samsung Galaxy J1 Motherboard Replacement
  1. Samsung Galaxy J1 Motherboard Replacement, Midframe: step 1, image 1 of 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Motherboard Replacement: step 2, image 1 of 2 Samsung Galaxy J1 Motherboard Replacement: step 2, image 2 of 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Motherboard Replacement: step 3, image 1 of 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Motherboard Replacement: step 4, image 1 of 3 Samsung Galaxy J1 Motherboard Replacement: step 4, image 2 of 3 Samsung Galaxy J1 Motherboard Replacement: step 4, image 3 of 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Motherboard Replacement, Motherboard: step 5, image 1 of 2 Samsung Galaxy J1 Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Use the flat edge of a spudger to disconnect the ear speaker connector.
  6. Samsung Galaxy J1 Motherboard Replacement: step 6, image 1 of 2 Samsung Galaxy J1 Motherboard Replacement: step 6, image 2 of 2
    • Use the flat end of a spudger disconnect the digitizer connector.
  7. Samsung Galaxy J1 Motherboard Replacement: step 7, image 1 of 2 Samsung Galaxy J1 Motherboard Replacement: step 7, image 2 of 2
    • Use the flat end of a spudger disconnect the front-facing camera cable connector.
  8. Samsung Galaxy J1 Motherboard Replacement: step 8, image 1 of 2 Samsung Galaxy J1 Motherboard Replacement: step 8, image 2 of 2
    • Remove the front-facing camera.
  9. Samsung Galaxy J1 Motherboard Replacement: step 9, image 1 of 3 Samsung Galaxy J1 Motherboard Replacement: step 9, image 2 of 3 Samsung Galaxy J1 Motherboard Replacement: step 9, image 3 of 3
    • Use the flat end of a spudger to gently pry under the motherboard.
    • Remove the motherboard.
  10. Samsung Galaxy J1 Motherboard Replacement: step 10, image 1 of 1
    • Use the flat end of a spudger to disconnect the rear camera cable connector.
  11. Samsung Galaxy J1 Motherboard Replacement: step 11, image 1 of 2 Samsung Galaxy J1 Motherboard Replacement: step 11, image 2 of 2
    • Remove the rear camera.
23 other people completed this guide.
Sean Kramer
1,560 Reputation
6 Guides authored
USF Tampa, Team S5-G4, Eyestone Spring 2018 Member of USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Members
6 Guides authored
4 Comments
can you plz give use a amazon link to part
Sean Gynn - Reply
Very good illustration..where can I get a motherboard?
Isaac Samuels - Reply
Where can I get a motherboard for this phone Samsung J100?
I need the details of the motherboard
FUN FIRST - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 49
All Time: 7,089
