Samsung Galaxy J1 Volume Button Replacement
  1. Samsung Galaxy J1 Volume Button Replacement, Midframe: step 1, image 1 of 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Volume Button Replacement: step 2, image 1 of 2 Samsung Galaxy J1 Volume Button Replacement: step 2, image 2 of 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Volume Button Replacement: step 3, image 1 of 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Volume Button Replacement: step 4, image 1 of 3 Samsung Galaxy J1 Volume Button Replacement: step 4, image 2 of 3 Samsung Galaxy J1 Volume Button Replacement: step 4, image 3 of 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Volume Button Replacement, Volume Button: step 5, image 1 of 2 Samsung Galaxy J1 Volume Button Replacement, Volume Button: step 5, image 2 of 2
    • Use the flat edge of a spudger to push the volume button out.
    • Remove the volume button.
5 other people completed this guide.
Sean Kramer
1,506 Reputation
6 Guides authored
USF Tampa, Team S5-G4, Eyestone Spring 2018 Member of USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 29
All Time: 1,919
