Samsung Galaxy J3 Motherboard Replacement
  1. Samsung Galaxy J3 Motherboard Replacement, Back Cover Removal: step 1, image 1 of 1
    • Unplug the device from the charging dock if it is connected. Power off the device. Then using your fingernails, pop off the back cover of the device.
  2. Samsung Galaxy J3 Motherboard Replacement, Battery Removal: step 2, image 1 of 1
    • Remove the battery from the casing.
  3. Samsung Galaxy J3 Motherboard Replacement, Main Body Removal: step 3, image 1 of 1
    • Remove the screws using a Philips #00 screwdriver .
    • Remember to keep your screws organized!
  4. Samsung Galaxy J3 Motherboard Replacement: step 4, image 1 of 2 Samsung Galaxy J3 Motherboard Replacement: step 4, image 2 of 2
    • Using a metal spudger, pry the mid frame out.
    • Do not use a wrenching motion or the screen will crack.
  5. Samsung Galaxy J3 Motherboard Replacement: step 5, image 1 of 3 Samsung Galaxy J3 Motherboard Replacement: step 5, image 2 of 3 Samsung Galaxy J3 Motherboard Replacement: step 5, image 3 of 3
    • Use a spudger or your fingernails to disconnect the screen connector.
    • Use a spudger or your fingernails to disconnect the connector cable.
  6. Samsung Galaxy J3 Motherboard Replacement: step 6, image 1 of 1
    • Remove the motherboard.
    • It should come off easily, if not, some screws might still be connected.
6 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 53
All Time: 8,885
