Samsung Galaxy J3V Headphone Jack Replacement
  1. Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: step 1, image 1 of 3 Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: step 1, image 2 of 3 Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: step 1, image 3 of 3
    • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
  2. Samsung Galaxy J3V Headphone Jack Replacement: step 2, image 1 of 3 Samsung Galaxy J3V Headphone Jack Replacement: step 2, image 2 of 3 Samsung Galaxy J3V Headphone Jack Replacement: step 2, image 3 of 3
    • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
  3. Samsung Galaxy J3V Headphone Jack Replacement: step 3, image 1 of 3 Samsung Galaxy J3V Headphone Jack Replacement: step 3, image 2 of 3 Samsung Galaxy J3V Headphone Jack Replacement: step 3, image 3 of 3
    • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
    • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
  4. Samsung Galaxy J3V Headphone Jack Replacement: step 4, image 1 of 3 Samsung Galaxy J3V Headphone Jack Replacement: step 4, image 2 of 3 Samsung Galaxy J3V Headphone Jack Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove connector tab with spudger then carefully remove headphone jack with tweezers.
Carry Corrales
792 Reputation
5 Guides authored
USF Tampa, Team S3-G3, Nance Fall 2017 Member of USF Tampa, Team S3-G3, Nance Fall 2017
USFT-NANCE-F17S3G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 584
