Samsung Galaxy J5 2017 Display Replacement
Smilzo
Smilzo and 4 other contributors
Last updated on August 26, 2022
35 minutes
Easy
Grammar Police
Bullets!
Needs Better Images
Community-Contributed Guide
Introduction
Go to step 1
Use this guide to replace a cracked or dead screen in your Samsung Galaxy J5.
If the frame is warped, it is important to replace it to make sure the new screen fits properly and does not suffer damage from uneven pressure.
Before disassembling your mobile, discharge the battery below 25%. The battery could catch fire and / or explode if accidentally punctured, but the chances are much lower if it is discharged.
Note: This guide tells you how to replace the screen only, leaving the original chassis and motherboard in place. However, some replacement screens come pre-installed in a new chassis, which requires a very different procedure. Make sure you have the correct part before you start following this guide.
You will need replacement adhesive to re-glue the components when reassembling the device.
Tools
Show more…
  1. Samsung Galaxy J5 2017 Display Replacement, Display: step 1, image 1 of 2 Samsung Galaxy J5 2017 Display Replacement, Display: step 1, image 2 of 2
    • With a hair dryer, heat the glass well so that the adhesive glue can detach easily.
    • Use thin tools all over the profile and insert them between the plastic frame and the glass.
    • Do not insert the opening tools you are using between the aluminum and the plastic frame.
  2. Samsung Galaxy J5 2017 Display Replacement: step 2, image 1 of 3 Samsung Galaxy J5 2017 Display Replacement: step 2, image 2 of 3 Samsung Galaxy J5 2017 Display Replacement: step 2, image 3 of 3
    • Lift the display from bottom to top where the flat and connector is connected.
    • Remove the black snap-on lid.
    • Unclip the connector.
    • Thoroughly clean the surfaces of glue residues and install the replacement display.
To reassemble the device, follow these instructions in reverse order.
11 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,849 Reputation
39 Guides authored
2 Comments
Questo Samsung ha davvero un sistema di sostituzione dello schermo molto pratico.
tanner85 - Reply
Certo ma se devi cambiare la batteria? Rompi lo schermo al 99%
Francesco Cogliano -
Past 24 Hours: 7
Past 7 Days: 50
Past 30 Days: 163
All Time: 8,288
