Samsung Galaxy J7 Battery Replacement
  1. Samsung Galaxy J7 Battery Replacement, Back Cover: step 1, image 1 of 2 Samsung Galaxy J7 Battery Replacement, Back Cover: step 1, image 2 of 2
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Battery Replacement, Battery: step 2, image 1 of 2 Samsung Galaxy J7 Battery Replacement, Battery: step 2, image 2 of 2
    • Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
    • Remove Battery: Gently pop out the edge and carefully pull out the battery.
    • Tip: Ensure the battery is disconnected from the motherboard before removing it.
11 other people completed this guide.
0 Comments
Past 24 Hours: 5
Past 7 Days: 47
Past 30 Days: 129
All Time: 12,865
