Samsung Galaxy J7 Front Facing Camera Replacement
  1. Samsung Galaxy J7 Front Facing Camera Replacement, Back Cover: step 1, image 1 of 2 Samsung Galaxy J7 Front Facing Camera Replacement, Back Cover: step 1, image 2 of 2
    • Remove the back of the device by pulling on the tab in the top left.
  2. Samsung Galaxy J7 Front Facing Camera Replacement, Midframe: step 2, image 1 of 1
    • Using the Phillips #000 screwdriver, remove ten 4.2 mm screws.
  3. Samsung Galaxy J7 Front Facing Camera Replacement: step 3, image 1 of 3 Samsung Galaxy J7 Front Facing Camera Replacement: step 3, image 2 of 3 Samsung Galaxy J7 Front Facing Camera Replacement: step 3, image 3 of 3
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
  4. Samsung Galaxy J7 Front Facing Camera Replacement, Front Facing Camera: step 4, image 1 of 1
    • Remove single screw from back of device. This is the only screw that must be removed to take off this piece.
  5. Samsung Galaxy J7 Front Facing Camera Replacement: step 5, image 1 of 1
    • Make sure to pull up all of these parts in order to properly take off the next piece.
  6. Samsung Galaxy J7 Front Facing Camera Replacement: step 6, image 1 of 2 Samsung Galaxy J7 Front Facing Camera Replacement: step 6, image 2 of 2
    • Pull the blue/green piece away from the black piece. They should not need any force to be removed. The next step will deal with using the green/blue piece from the second picture.
  7. Samsung Galaxy J7 Front Facing Camera Replacement: step 7, image 1 of 2 Samsung Galaxy J7 Front Facing Camera Replacement: step 7, image 2 of 2
    • Flip over the piece (180 degrees). Remove the boxed out piece. This is the front facing camera.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 335
