Samsung Galaxy J7 V Earpiece Speaker Replacement
  1. Samsung Galaxy J7 V Earpiece Speaker Replacement, Screen: step 1, image 1 of 1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 V Earpiece Speaker Replacement: step 2, image 1 of 1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 V Earpiece Speaker Replacement: step 3, image 1 of 1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 V Earpiece Speaker Replacement, Home button: step 4, image 1 of 1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 V Earpiece Speaker Replacement: step 5, image 1 of 1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 V Earpiece Speaker Replacement, Motherboard: step 6, image 1 of 1
    • Remove fourteen screws from the midframe using a Phillips #00 screwdriver.
  7. Samsung Galaxy J7 V Earpiece Speaker Replacement: step 7, image 1 of 1
    • Flip the phone to the back side where the battery was removed.
    • Apply pressure with your hands to pop the midframe off.
  8. Samsung Galaxy J7 V Earpiece Speaker Replacement: step 8, image 1 of 2 Samsung Galaxy J7 V Earpiece Speaker Replacement: step 8, image 2 of 2
    • Flip the phone back over.
    • Remove the single black screw from the motherboard using a Phillips #00 screwdriver.
    • Place a few iFixit opening picks beneath the motherboard.
    • Spread the opening picks evenly around the motherboard to ensure it does not bend as you remove it.
    • Lift the motherboard using the iFixit opening picks.
  9. Samsung Galaxy J7 V Earpiece Speaker Replacement, Earpiece Speaker: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to remove the back of the earpiece speaker.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 34
All Time: 827
