Introduction
Having trouble with your Samsung Galaxy J7 V Power Button? With this guide, you can learn how to replace the power button and continue using your phone for years to come.
The power button is a critical part of a mobile phone, as it allows you to turn on and off the display of the phone. If the button begins sticking or not working properly, it can cause the display on the phone to not turn on, or other similar issues. It is critical to fix this issue so that you can continue using your phone.
Before starting, if possible, power off your phone completely and disconnect from any external power source.
Follow the steps below with care, precision, and a little bit of patience, and you will have your Samsung Galaxy J7 Phone working properly again!
Insert a Jimmy tool under one of the corners of the display and gently raise the display.
Locate the socket of the home button.
Fit the metal spudger in between the socket and the home button.
Use the metal spudger tool to lift the metal bar holding the button in place.
To reassemble your device, follow these instructions in reverse order. Please don't miss a screw!
3 other people completed this guide.
