Samsung Galaxy J7 v Volume Button Replacement
  1. Samsung Galaxy J7 v Volume Button Replacement, Screen: step 1, image 1 of 1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 v Volume Button Replacement: step 2, image 1 of 1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 v Volume Button Replacement: step 3, image 1 of 1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 v Volume Button Replacement, Home button: step 4, image 1 of 1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 v Volume Button Replacement: step 5, image 1 of 1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 v Volume Button Replacement, Volume Button: step 6, image 1 of 2 Samsung Galaxy J7 v Volume Button Replacement, Volume Button: step 6, image 2 of 2
    • Remove the screws around the home button and the screws above.
  7. Samsung Galaxy J7 v Volume Button Replacement: step 7, image 1 of 1
    • Pull the screen away from the panel.
  8. Samsung Galaxy J7 v Volume Button Replacement: step 8, image 1 of 2 Samsung Galaxy J7 v Volume Button Replacement: step 8, image 2 of 2
    • Remove all adjacent screws.
  9. Samsung Galaxy J7 v Volume Button Replacement: step 9, image 1 of 3 Samsung Galaxy J7 v Volume Button Replacement: step 9, image 2 of 3 Samsung Galaxy J7 v Volume Button Replacement: step 9, image 3 of 3
    • Pop off panel from plastic hold.
  10. Samsung Galaxy J7 v Volume Button Replacement: step 10, image 1 of 3 Samsung Galaxy J7 v Volume Button Replacement: step 10, image 2 of 3 Samsung Galaxy J7 v Volume Button Replacement: step 10, image 3 of 3
    • Use the pointed end of the spudger to push down the button hold, then the volume button can be removed by pushing it down.
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 41
All Time: 970
