Samsung Galaxy Light Earpiece Speaker Replacement
  1. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Back Cover: step 1, image 1 of 1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Battery: step 2, image 1 of 1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Earpiece Speaker Replacement, Unscrew Midframe: step 3, image 1 of 1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Midframe: step 4, image 1 of 1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: step 5, image 1 of 3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: step 5, image 2 of 3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: step 5, image 3 of 3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: step 6, image 1 of 2 Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: step 6, image 2 of 2
    • Use a plastic opening tool to pry up the headphone jack, vibrator, and earpiece speaker assembly.
4 other people completed this guide.
Paul Goyette
475 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 706
