Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement
  1. Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement, Remove SIM Card Tray: step 1, image 1 of 3 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement, Remove SIM Card Tray: step 1, image 2 of 3 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement, Remove SIM Card Tray: step 1, image 3 of 3
    • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
    • Press firmly to eject the tray.
  2. Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 2, image 1 of 3 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 2, image 2 of 3 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 2, image 3 of 3
    • Insert an opening pick between the phone assembly and the back cover at the bottom edge of the phone.
    • Slide the opening pick around the bottom right corner to release the clips holding the back cover in place.
  3. Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 3, image 1 of 2 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 3, image 2 of 2
    • Insert a second opening pick between back cover and the phone assembly at the bottom edge of the phone.
    • Slide the opening pick around the bottom left corner to release the plastic clips holding the back cover in place.
  4. Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 4, image 1 of 2 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 4, image 2 of 2
    • Slide the opening pick along the left side of the phone to release the plastic clips on the left side of the back cover.
  5. Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 5, image 1 of 2 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 5, image 2 of 2
    • Slide the opening pick along the right side of the phone to release the plastic clips on the right side of the back cover.
  6. Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement, Remove Back Cover: step 6, image 1 of 3 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement, Remove Back Cover: step 6, image 2 of 3 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement, Remove Back Cover: step 6, image 3 of 3
    • The flex cable of the fingerprint sensor is very short and the sensor is likely to disconnect itself during the following removal procedure. Avoid damaging the cable by removing the back cover too quickly.
    • Carefully lift the phone assembly out of the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before reinstalling the back cover. Be sure to power your phone back down completely before you continue working.
  7. Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement, Soften Fingerprint Adhesive: step 7, image 1 of 1
    • Apply a heated iOpener to the back of the phone where the fingerprint sensor is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  8. Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 8, image 1 of 3 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 8, image 2 of 3 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement: step 8, image 3 of 3
    • Slide an opening pick underneath the edge of the fingerprint reader.
    • Slide the opening pick around the edge of the fingerprint reader to cut the adhesive underneath.
  9. Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement, Remove Fingerprint Sensor: step 9, image 1 of 2 Samsung Galaxy M31 Back Cover & Fingerprint Sensor Replacement, Remove Fingerprint Sensor: step 9, image 2 of 2
    • Remove the fingerprint reader.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Secure the fingerprint sensor with pre-cut adhesive or double-sided adhesive tape during reassembly.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
6 other people completed this guide.
Dominik Schnabelrauch
211,728 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,059 Guides authored
2 Comments
What type of adhesive is best to use to stick the back cover back on. Glue or tape?
legga001 - Reply
лучше если останется заводской скотч.
если вы его убрали то используйте 3m скотч.
если вы заклеите на клей то потом крйне сложно будет отклеить заднюю крышку.
Сервисный Центр ПК-Партнер -
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 75
All Time: 4,006
