Samsung Galaxy Mega Midframe Replacement
  1. Samsung Galaxy Mega Midframe Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Mega Midframe Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Mega Midframe Replacement, Battery: step 1, image 3 of 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Midframe Replacement: step 2, image 1 of 3 Samsung Galaxy Mega Midframe Replacement: step 2, image 2 of 3 Samsung Galaxy Mega Midframe Replacement: step 2, image 3 of 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Midframe Replacement, Midframe: step 3, image 1 of 3 Samsung Galaxy Mega Midframe Replacement, Midframe: step 3, image 2 of 3 Samsung Galaxy Mega Midframe Replacement, Midframe: step 3, image 3 of 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Midframe Replacement: step 4, image 1 of 2 Samsung Galaxy Mega Midframe Replacement: step 4, image 2 of 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
5 other people completed this guide.
Aaron Fulton
1,246 Reputation
3 Guides authored
USF Tampa, Team 17-2, Blackwell Winter 2016 Member of USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,095
