Samsung Galaxy Mega Motherboard Replacement
  1. Samsung Galaxy Mega Motherboard Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Mega Motherboard Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Mega Motherboard Replacement, Battery: step 1, image 3 of 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Motherboard Replacement: step 2, image 1 of 3 Samsung Galaxy Mega Motherboard Replacement: step 2, image 2 of 3 Samsung Galaxy Mega Motherboard Replacement: step 2, image 3 of 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Motherboard Replacement, Midframe: step 3, image 1 of 3 Samsung Galaxy Mega Motherboard Replacement, Midframe: step 3, image 2 of 3 Samsung Galaxy Mega Motherboard Replacement, Midframe: step 3, image 3 of 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Motherboard Replacement: step 4, image 1 of 2 Samsung Galaxy Mega Motherboard Replacement: step 4, image 2 of 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Remove the 2.55 mm Phillips #000 screw from the motherboard panel.
  6. Samsung Galaxy Mega Motherboard Replacement: step 6, image 1 of 3 Samsung Galaxy Mega Motherboard Replacement: step 6, image 2 of 3 Samsung Galaxy Mega Motherboard Replacement: step 6, image 3 of 3
    • Remove the connector clips on motherboard.
  7. Samsung Galaxy Mega Motherboard Replacement: step 7, image 1 of 2 Samsung Galaxy Mega Motherboard Replacement: step 7, image 2 of 2
    • Remove the final motherboard connectors.
  8. Samsung Galaxy Mega Motherboard Replacement: step 8, image 1 of 3 Samsung Galaxy Mega Motherboard Replacement: step 8, image 2 of 3 Samsung Galaxy Mega Motherboard Replacement: step 8, image 3 of 3
    • Lift motherboard gently with finger.
    • There is a total of six connectors on the motherboard that need to be removed. All of them are shown in the pictures in this guide, make sure all of them are disconnected before removing.
10 other people completed this guide.
Max Rathman
915 Reputation
4 Guides authored
USF Tampa, Team 17-2, Blackwell Winter 2016 Member of USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Members
8 Guides authored
5 Comments
Where can I buy a motherboard replacement for Mega 6.3 GT-I9205/I527?
valuesphilippines - Reply
Is there an international market to buy mobile phone hardware? I can not find motherboard for this phone in my country (online).
lukhman - Reply
Where can I buy the motherboard replacement for G. Mega 6.3 19200
Thats dae - Reply
i cant turn on my galay mega 6.3 afrer update phone is like DEAD!!!  please help me…..for Samsung mega gt-i9205
mirza baig - Reply
This app is the best
Mazen Noufal - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 5,446
