Samsung Galaxy Mega Speaker Assmebly Replacement
  1. Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: step 1, image 3 of 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Speaker Assmebly Replacement: step 2, image 1 of 3 Samsung Galaxy Mega Speaker Assmebly Replacement: step 2, image 2 of 3 Samsung Galaxy Mega Speaker Assmebly Replacement: step 2, image 3 of 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: step 3, image 1 of 3 Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: step 3, image 2 of 3 Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: step 3, image 3 of 3
    • Remove the 6 3.45 mm Phillips #000 screws from the bottom of the assembly surrounding the speaker.
    • Gently insert plastic opening tool through the inside groove of the speaker assembly.
    • Once the top part of the speaker assembly pops free. Gently lift up with your fingers to remove speaker.
nithin
137 Reputation
1 Guide authored
USF Tampa, Team 17-2, Blackwell Winter 2016 Member of USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 873
