So your Verizon Galaxy Nexus won't charge, charges sometimes, or thinks it's charging when it's not plugged in? It might be time to replace the micro USB connector board.
For this repair you'll need:
An opening tool.
Small Phillips screwdriver.
A replacement micro USB board. I found mine here.
Next we need to detach some ribbon cables and an antenna cable from the main circuit board.
Micro USB board. Also has the front notification LED and the main microphone.
Screen connector.
Volume rocker. Some phones have this soldered to the mainboard - not CDMA.
GSM/Soldered: One user was able leave the volume rocker alone, and instead focus on the power button. You can gently separate the power button from the case - held in place only by glue - without remove detaching it from the circuit board. You can then rotate the circuit board out of your way.
Antenna.
Gently detach with the plastic opening tool.
151 other people completed this guide.
12 Comments
These guys figured out the GSM version:
http://www.japanmobiletech.com/2012/07/r...
I didn't need to break the orignal part as cannonfodder described.
Fantastic. I could use this and fix my Galaxy Nexus. What a relief!
Few suggestions though -
My Galaxy Nexus is of a GSM model - so the build inside is little different than what was depicted here for the CDMA one. I gathered some information from http://www.japanmobiletech.com/2012/07/r... on the GSM aspects. I also watched the Galaxy Nexus Disassembly and Asssembly video during the repair process - http://www.youtube.com/watch?v=B5fZzZANL....
It took me an hour roughly to successfully finish the job. Thank you Sam.
GSM OWNERS
Read the comments before you proceed with this guide. There are some notable differences between CDMA and GSM, including:
* Volume and power buttons are probably soldered to the mainboard
* The vibrator is separate from the bottom speaker assembly and should be carefully removed using a spudger (but be careful not to tear the soldered wires
* The screws are located in different positions, all on top of the back plastic cover
** Step 4: I didn't have an additional screw below the plastic back
* Comments on Step 7 are great - to replace the USB ribbon, you must gently lift the bottom of the mainboard up, slide out the old USB ribbon, and slide the new one in. Don't take the mainboard completely out, or you'll break the soldered power and volume connections.
Good luck and happy fixing!
Was super easy for CDMA, I broke the clip in Step 5 but it still works!
Thanks for the great guide. I've dropped my phone a couple times with the USB cord plugged in and the port had gotten stretched a little bigger. I was able to get to the port and used a pair of needlenose pliers to make the port a little smaller. Now my USB cord stays in like its supposed to. Thanks so much!
