Samsung Galaxy Note 10.1 Motherboard Replacement
  1. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Top Piece: step 1, image 1 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Top Piece: step 1, image 2 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Top Piece: step 1, image 3 of 3
    • This is the back of the device and where you will begin to take it apart
    • It is neccesary to remove this piece first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Back Cover: step 2, image 1 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Back Cover: step 2, image 2 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Back Cover: step 2, image 3 of 3
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing components covering battery: step 3, image 1 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing components covering battery: step 3, image 2 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing components covering battery: step 3, image 3 of 3
    • Carefully remove all of the ribbons that connect over the battery.
  4. Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Battery: step 4, image 1 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Battery: step 4, image 2 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Removing the Battery: step 4, image 3 of 3
    • Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
  5. Samsung Galaxy Note 10.1 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Samsung Galaxy Note 10.1 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Flip the tablet 180 degrees for this step so the motherboard is easier to access.
    • Disconnect the cable connectors from the motherboard by gently lifting the connection hubs.
    • Remove each ribbon cable by lifting the locking mechanism on the casing holding the cable.
    • Gently pull the ribbon cable from the casing with your fingers or tweezers.
    • Carefully remove ribbon cables. Ribbon cables are easy to damage and may not always appear damaged. Any damage could potentially cause your device not to work.
  6. Samsung Galaxy Note 10.1 Motherboard Replacement: step 6, image 1 of 1
    • Remove the motherboard by gently sliding it out of its casing.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 16
All Time: 2,794
