Samsung Galaxy Note 10.1 microSD Port Replacement
  1. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: step 1, image 1 of 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: step 1, image 2 of 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: step 1, image 3 of 3
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: step 2, image 1 of 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: step 2, image 2 of 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: step 2, image 3 of 3
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: step 3, image 1 of 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: step 3, image 2 of 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: step 3, image 3 of 3
    • Unscrew the two 2 mm screws indicated by the red circles with the #00 Philips Screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the red box in the second picture.
    • Replace the microSD port with a similar model.
5 other people completed this guide.
Tyler Salomone
1,020 Reputation
3 Guides authored
USF Tampa, Team 3-7, Brown Fall 2014 Member of USF Tampa, Team 3-7, Brown Fall 2014
USFT-BROWN-F14S3G7
3 Members
9 Guides authored
2 Comments
Be sure to include screw lengths to the nearest mm on all guides.
Dan Brown - Reply
In this guide, you missed a step on removing the battery.
John Peterson - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 3,918
