Samsung Galaxy Note 3 Display Assembly Replacement
  1. Samsung Galaxy Note 3 Display Assembly Replacement, Remove the rear case: step 1, image 1 of 1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: step 2, image 1 of 2 Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: step 2, image 2 of 2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Samsung Galaxy Note 3 Display Assembly Replacement, Battery: step 3, image 1 of 2 Samsung Galaxy Note 3 Display Assembly Replacement, Battery: step 3, image 2 of 2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Display Assembly Replacement, S Pen: step 4, image 1 of 1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Display Assembly Replacement, Unscrew Back Chassis: step 5, image 1 of 1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Back Chassis: step 6, image 1 of 1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: step 7, image 1 of 2 Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: step 7, image 2 of 2
    • Remove the single screw beside headphone jack.
  8. Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: step 8, image 1 of 2 Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Display Assembly Replacement, Motherboard Removal: step 9, image 1 of 1
    • Pull up on the motherboard with tweezers.
  10. Samsung Galaxy Note 3 Display Assembly Replacement, Spudger Tool Placement: step 10, image 1 of 1
    • Insert the spudger into the headphone jack.
  11. Samsung Galaxy Note 3 Display Assembly Replacement, Lift to Separate Headphone Jack: step 11, image 1 of 1
    • Lift the spudger to separate the jack assembly from the motherboard.
    • Pull to remove.
  12. Samsung Galaxy Note 3 Display Assembly Replacement, Metal Bracket Removal: step 12, image 1 of 1
    • Remove the metal bracket located in the top left hand corner.
  13. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Vibrating Motor: step 13, image 1 of 1
    Buy
    • Remove the vibrating motor by pulling up on it carefully with the tweezers.
  14. Samsung Galaxy Note 3 Display Assembly Replacement, USB Port Removal: step 14, image 1 of 1
    • Lift USB port from the front assembly using the tweezers.
  15. Samsung Galaxy Note 3 Display Assembly Replacement, Display Assembly: step 15, image 1 of 1
    • You are now left with the display assembly.
146 other people completed this guide.
Brittany Gail
8,539 Reputation
8 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2014 Member of USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Members
25 Guides authored
10 Guide Comments
είναι απόλυτα κατανοητό.
chandr - Reply
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace the digitizer?
rob lang - Reply
to safely remove the LCD display from the front touch screen glass w/o damaging the LCD screen I advise you to invest in and familiarize yourself with an LCD Separator machine and all the accessories that go along with it. Also, search for the machine and watch the videos..
tkflenorl - Reply
sunil - Reply
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace touch
sunil - Reply
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 156
All Time: 124,129
