Samsung Galaxy Note 3 Headphone Jack Replacement
  1. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove the rear case: step 1, image 1 of 1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Case from the Base: step 2, image 1 of 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Case from the Base: step 2, image 2 of 2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Samsung Galaxy Note 3 Headphone Jack Replacement, Battery: step 3, image 1 of 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Battery: step 3, image 2 of 2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Headphone Jack Replacement, S Pen: step 4, image 1 of 1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Headphone Jack Replacement, Unscrew Back Chassis: step 5, image 1 of 1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Back Chassis: step 6, image 1 of 1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Headphone Jack Replacement, Screw Removal: step 7, image 1 of 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Screw Removal: step 7, image 2 of 2
    • Remove the single screw beside headphone jack.
  8. Samsung Galaxy Note 3 Headphone Jack Replacement, Unfasten Clips and Cable Connectors: step 8, image 1 of 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Unfasten Clips and Cable Connectors: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Headphone Jack Replacement, Motherboard Removal: step 9, image 1 of 1
    • Pull up on the motherboard with tweezers.
  10. Samsung Galaxy Note 3 Headphone Jack Replacement, Spudger Tool Placement: step 10, image 1 of 1
    • Insert the spudger into the headphone jack.
  11. Samsung Galaxy Note 3 Headphone Jack Replacement, Lift to Separate Headphone Jack: step 11, image 1 of 1
    • Lift the spudger to separate the jack assembly from the motherboard.
    • Pull to remove.
23 other people completed this guide.
Brittany Gail
8,513 Reputation
8 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2014 Member of USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Members
25 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 15,129
