Samsung Galaxy Note 4 Battery Replacement
  1. Samsung Galaxy Note 4 Battery Replacement, Battery: step 1, image 1 of 1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
56 other people completed this guide.
Geoff Wacker
92,283 Reputation
89 Guides authored
9 Guide Comments
I updated my phone and the problem is that my phone just goes all black all the time and my phone it won't turn on and sometimes my phone restarts by itself and after the carrier goes on and on after a few mins it repeatedly goes black.
Can someone please me what's wrong with my phone. I have a Samsung Note 4.
Jessica Lee - Reply Share
Seems like your mobile device may be stuck in whats called, BootLoop Mode.
Gabe - Share
Yeah. One time my Note 4 did that too. It has an Otter case. What happened was I put the phone in topside down position into the rubber part. By mistake, of course. Corrected that and the problem was solved.
Tony - Share
Each time I trimmed my nails. It was impossible to open the back cover and had to use a mini screwdriver to open. Quite inconvenient. So I attached a small piece of clear packing tape (not the flimsy Scotchtape) to the inside of the cover's recess, with enough length sticking out to the side. Grab that tape and pull back on the cover. Voila. The otter case covers the tape, so the phone looks normal in use.
Tony - Share
hi
can i now its Compatibility with note 4 ( 2 sim ) ???? or Compatibility with 1 sim ????
aigoostore - Reply Share
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 105
All Time: 35,125
