Samsung Galaxy Note 8.0 Back Cover Replacement
  1. Samsung Galaxy Note 8.0 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Back Cover Replacement: step 2, image 1 of 1
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Back Cover Replacement: step 3, image 1 of 1
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
16 other people completed this guide.
Joel
1,878 Reputation
6 Guides authored
USF Tampa, Team 12-2, Blackwell Fall 2014 Member of USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 Members
16 Guides authored
4 Guide Comments
news flash that phone in the picture is NOT a note 8
Nic Wilson - Reply Share
As stated in the title, this is regarding Galaxy Note 8.0 ( 2013 ), not for Note 8 Phone.
deadyoda - Share
Thanks for the guide, helped me to add a QI module into my Galaxy Note 8.0
deadyoda - Share
Thanks for sharing this useful guide! Also, if issue is related with software, we can use unbrick guide to get it repair.
Cheers!
Deepak Gupta - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 78
All Time: 34,517
